QSO save button doesn't work
kb1ftb
Post by kb1ftb »
Just updated to v2.30.00 And now QSO save button in upper right corner does not save QSO. Button is green so it leads me to believe it works. But the QSO does not show up in the recent QSO (F7) tab window. The help and about windows shows the correct and current version. Is a change needed in the SQlite data location or something associated with it? I just assume that when i did upgrade everything would just update with out having to tweek. Other then this issue its working.
Regards
KB1FTB
Re: QSO save button doesn't work
kb1ftb wrote: 16 Nov 2023, 22:12 Just updated to v2.30.00 And now QSO save button in upper right corner does not save QSO. Button is green so it leads me to believe it works. But the QSO does not show up in the recent QSO (F7) tab window. The help and about windows shows the correct and current version. Is a change needed in the SQlite data location or something associated with it? I just assume that when i did upgrade everything would just update with out having to tweek. Other then this issue its working.
Regards
KB1FTB
John,
A hotfix release was just posted. Pls d/l that version: V2.30.1.0 and see if that resolves your issue.
I did not experience what you noted about the Save+ button when I was running and testing V2.30.0.0 so hard for me to address all that now.
Give the version I noted above an installation and pls advise.
kb1ftb
Post by kb1ftb »
Hi Nolan
Just started LOG4OM and got the update notice. Will update and see if it fixes QSO save issue. Thanks for the quick response!
Regards
John KB1FTB
