Trying to participate in ARRL Sweepstakes. I have the contest settings correct (see attached) but Log4OM V2 will not go into contest mode using either the dropdown or the button on the title bar.
Any ideas?
Jim -KC4JNW
Contest Mode
Contest Mode
- Contest Settings.jpg (21.27 KiB) Viewed 5845 times
Re: Contest Mode
Jim,
Start and End dates should be 1/1/23 to 12/31/23 ...
At least that is what comes up in my test setup to help you out.
You "end date" can't be back in 2020 ...
Change dates ...
Change dates ...
Re: Contest Mode
Thanks, I screwed up the end date.
Since I couldn't get Log4OM to work last night, I loaded up N1MM+ and got it working.
Jim -KC4JNW
Jim -KC4JNW
