Since my last post on this topic, I finally decided it was an issue in Log4OM due to me having to reload everything when forced into Windows 11.
After much frustration and trying a lot of things.. I found this to fix the problem:
1. Open QSL Manager
2. Select a date range, in my case I used the backup when Windows 10 went away.
3. Selected "Sent = YES" on the Search confirmation Specific.
4. Click Search Tab
5. Click Select required tab (they all turned blue)
6. Now check "Enable Update" to the right of the From date fields.
7. in the "Update selected QSO's confirmations" check "Sent" and YES in the pulldown.
8. Finally click the floppy disk icon.
9. Untick the "Enable Update"
Now when I have more than 8 contacts to send, it only shows the number that needs to be sent, not the whole log.
73!!
After reporting that loading into LTOW hangs, I found out on my system this:
1. If I have more than 8 contacts selected to upload, nothing gets sent and QSL Manager has to be closed, even though it says it is sending.
2. If I manually select 8 or less, upload works as in previous versions.
3. After Closing QSL Manager and trying to start again, it hangs immediately.
4. To get things working again, I closed Log4OM and started over.. only sending 8 at a time. Since sending to QRZ or Clublog is immediate there is no issue..
FYI,
73's
W8QH/V31XE
LTOW QSL Manager Issue -SOLVED
Re: LTOW QSL Manager Issue
TQSL Ver 2.7.1
Sorry I should have posted both versions:
Windows 11
Log4OM 2.30.1.0
TQSL 2.7.1
Windows 11
Log4OM 2.30.1.0
TQSL 2.7.1
Try entering your LOTW details again in case a rogue character has crept in, especially locationw8qh wrote: 24 Nov 2023, 12:55 Sorry I should have posted both versions:
Windows 11
Log4OM 2.30.1.0
TQSL 2.7.1
Download does not use TQSL only upload
Thanks Terry for trying, but redoing the info for TQSL in the program settings has not helped.
I can send less but not more than 8 at a time.
The log file is attached.
73's
W8QH/V31XE
73's
W8QH/V31XE
New Update Terry
So I found that for example more than 8, 15.. I have saved a bunch!
And I go through the steps, and after I get the pop-up to send to LTOW, instead of 15 it shows I have 576 to send. I don't know where to clear the counter that is accumulating the amount of QSO to send to LTOW.. somehow that is not being cleared after sending.. is it LTOW or Log4OM??
