I am running Log4OM 2 v.2.30.1.0 and have two user configurations defined. The 1st is my home QTH, the 2nd is a clone of the first with only the grid-square changed to reflect the other location.
In TQSL, I have a Station ID created for both locations' gridsquares and both are visible in the LOTW tab of the External Services section of Log4OM.
Does Log4OM have the ability to automatically choose the correct TQSL Station ID to use when uploading to LOTW? Or do I need to change it manually?
Thank you,
David
KC2ILK
Multiple User Configurations and LOTW TQSL Station IDs
Re: Multiple User Configurations and LOTW TQSL Station IDs
Normally Log4OM has the correct data if you stored it in the 2nd user configuration and it used this for upload.
Attention: You need a second LotW certificate for the second station ID with the other Locator. If you
don´t have this TQSL will not upload.
