addition of fields in qso manager dropdown
ve3wej
Post by ve3wej »
can fields be added by the user, or do they need to be programmed in. I see IOTA, and all the other ota's are not in list.
example p4/we9v, i would like to add sa-036 in the awards refence, without having to edit each contact
Dave ve3wej / ve3ie
Re: addition of fields in qso manager dropdown
Whats wrong with adding the reference as you work the guy?
You have a point though, I agree any ADIF recognised field apart from confirmations should be included in the single field update of QSO manager - I will attend to that
ve3wej
Post by ve3wej »
the iota info was not part of the transfer from wsjtx/jtalert to log4om. it was after logging several contacts that I found it missing, and wanted to add to 4 or contacts with one edit, not 4 or 5
Dave ve3wej / ve3ie
