Simplified LOG4OM to PC Transfer
WA2SQQ
Post by WA2SQQ »
If the user has to transfer LOG4OM to another PC, I believe it requires certain files in addition to the SQL and .ADI files must be copied and saved to the new PC.
It would make this task much easier if a feature (batch file?) could be executed by just one click. The user would designate where the files need to be copied to.
I do not believe this feature exists.
ei6kw
Re: Simplified LOG4OM to PC Transfer
Post by ei6kw »
Migration to the new computer is quite easy without that.
From user manual, page 249:
Transferring Log4OM set up to another PC
To replicate the configuration of an existing Log4OM installation including the field arrangements in grids
and cluster.
Copy the contents of the 'USER' folder C:\Users\YOUR USER NAME\AppData\Roaming\Log4OM2\user to the
same folder on the other machine and allow the files to overwrite those of the second machine
__
73!
de EI6KW, Slav
[url]https://www.hamqth.com/ei6kw[/url]
WA2SQQ
Post by WA2SQQ »
Thank you for your quick response. Yes, I know that but for some new users who may not be so familiar with PC operation, think of how easy it would be if you simply click this option and say where you want the files copied.... Just suggesting this to simplify the requirement
