Rx Band
w9mdb
Rx Band
Post by w9mdb »
When saving a QSO and you have a bad Rx Freq Log4OM does not confirm that the Band contains the Rx Frequency.
Since you can't make Rx Frequency blank (error during save) then seems like a check should be done to ensure the Rx Frequency is in-band and an error during save when it does not match.
This showed up with a friend of mine who put the frequency in MHz instead of KHz (14 instead of 14000) and the band goes blank, he manually selected but still have 14 in the frequency and didn't realize that is KHz and not MHz.
If an error check was done it would have given him a slap-in-the-face.
