linux
KA5MWB
linux
Post by KA5MWB »
hi
will lo40m run on linux i have window xp ?
thanks
ka5mwb
Re: linux
Runs on any Windows platform from XP and above.
Does not run on Linux or Mac.
Re: linux
Some years ago i´ve experimented with UBUNTU linux ..... Have tested some loggers which are only for Windows. It may work but you need a "Virtual Machine" Software where you can install a windows XP inside your Linux distribution. Then you may try to install L4O and it´s needed components (Net Framework e.g.). But you have to know ---- if it work´s it´s impossible to connect Fldigi (or other software installed at Linux) to your L4O in the virtual machine .... So you need also Windows versions of other softwares that runs inside the VM. All a bit "tricky" but possible ...
