Loading onto a new drive with Win 11
K8TJM
Post by K8TJM »
Hello All,
I'm using WJST-X, Grid Tracker and Log4OM.
How Log4OM use to work on the old drive: I would click on a call on the left panel in WJST-X that I wanted a QSO with. It would automatically populate the upper left area where the call sign would go. It would also do a lookup on QRZ to populate the country etc. After the QSO ended I would log it from WSJT-X and it would automatically log Log4OM.
Now when I click on a call in WSJT-X it will no longer populate the Callsign field et al. It will however log properly when I log it from WSJT-X.
Should the proper way be what I described in the first example or the second? I'm not sure if it was a fluke when it would automatically populate the upper left Callsign area.
Thanks & Merry Christmas!
Terry / K8TJM (so far not a big fan of Win11 but it is free and I read that MS will be dropping support for Win 10 soon).
K8TJM
Re: Loading onto a new drive with Win 11
Post by K8TJM »
I found the video that helped me set it up the first time. The video is here so that others might benefit. :
https://www.youtube.com/watch?v=j479cJElhLc
Terry / K8TJM
