4O3A Antenna Genius
n3fb
4O3A Antenna Genius
Post by n3fb »
I am running Log4OM V2 version: 2.30.1.0.
I would like to know if It is possible for Log4OM to read the antenna status from the 4O3A Antenna Genius and have that antenna name populate the antenna field of the contact. The Antenna Genius communicates via TCPIP on a port. It will allow control or report status on this port.
Here is why - I will change the antenna and forget to press F4 to change the drop down manually. Reading it from the Antenna Genius would help me to keep this accurate.
I do have antennas set up in Log4OM, that helps. My problem is when I have more than 1 antenna for a band.
Thank You.
Frank. N3FB
N3FB
Frank Bobro
Re: 4O3A Antenna Genius
Sorry not possible
