WAB - Worked All Brazil
Moderator: OE6CLD
OE6CLD
Post by OE6CLD »
Hi all,
Please find attached the award definition for the WAB - Worked All Brazil award. Copy the attached xml file (it should be named award_WABR.xml) into the <user>/AppData/Roaming/LogOM/awards folder and restart Log4OM.
Right at the moment there are a lot of special event stations from all Brazilian states active. I had to name this award WABR, because WAB already has been used for Worked All Britain.
More information regarding the award can be found here: http://www.labre.org.br/crbst_11.html
Claus, EI7JZ/OE6CLD
award_WABR.xml
(17.99 KiB) Downloaded 616 times
WAB - Worked All Brazil.jpg (660.72 KiB) Viewed 4340 times
Claus, OE6CLD/DJ0DX/EI7JZ
