An option to Lock TCI to either RX1 or RX2
LB2EG
Post by LB2EG »
Using Log4OM with my SunSDR2-DX (with ESDR v3), I tend to use the Log4OM TCI CAT control on RX1 looking for CW DX, while looking for FT8 contacts on RX2.
This works quite well, but as LOG4OM TCI CAT changes between RX1 and RX2 due to which RX is active, It is a bit annoying when Log4OM changes QRG and Mode on RX2 when I click on a DX spot (which I intended should change RX1) .
I do request at it is added an option in Log4OM to lock the program to either RX1 or RX2 or have separate TCI connections to RX1 and RX2 as seen in other programs.
I am using the latest beta.
73 de LB2EG Richard
