According to the Log4OM User Manual (page 228 in my version), you are supposed to be able to setup FLDigi and Log4OM so that "the entered call sign in FLDigi to be displayed and looked up in Log4OM". I can't make this work.
Getting Log4OM to read the FLDigi log using the ADIF function is no problem - all works 100%.
Getting Log4OM or FLDigi to read the Rig frequency and Mode is no problem - all works 100%.
BUT it would be nice having entering a Callsign in FLDigi for the info to automatically be read by Log4OM so it can do a lookup for the Station details.
I am using Log4OM v 2.30.1.0, FLDigi v 4.2.03 and WIN10 Pro 64bit.
And yes, I have double-checked that both programs are set to use Port 7362.
Any thoughts, anyone, as to whether this feature still works on the current versions?
FLDigi Callsign NOT sending to Log4OM
- Novice Class
73, Peter G3ZPB
Re: FLDigi Callsign NOT sending to Log4OM
Confirmed! something changed in FLDigi we will look into it
- Novice Class
Thanks Terry.
It's good to know it's not me that can't follow simple instructions!!!
73, Peter G3ZPB
I'm glad it's not just me! I have tried getting the FLDIGI -> Log4OM connection for call lookup working several times in the past year or so.
I'll be patiently waiting and hoping that there is an easy solution to get it working.
Cheers,
Steve K4RVA
Cheers,
Steve K4RVA
I see. I didn't know about it because I couldn't read manuals with automatic translation until recently.
Callsigns can be sent from Log4OM to fldigi, but I thought there was no function to send callsigns from fldigi to Log4OM.
I think it would be convenient if the function to send a call sign from fldigi to Log4OM works.
73, Kiyo JA9HWD
