User defined world map
N8XMS
Post by N8XMS »
Does anyone know of a file, for the "user defined world map", with correct dimensions for accurate grey-line display, that would also show political country boundaries, instead of the standard physical maps supplied with log4OM?
Thanks,
Paul - N8XMS
Re: User defined world map
Google is your friend
https://visibleearth.nasa.gov/
N8XMS
Post by N8XMS »
Hi Terri,
Thank you for your speedy reply. There are some amazing pictures in that NASA directory, and there are certainly plenty of free maps available on the internet. I guess what I really need to know is what map dimensions are necessary so that the grey-line display laid on top of the map, in the main map window, is accurate. I tested one map file that I had but the map was a little distorted to fit into the window and the grey-line was not correct on it.
Paul - N8XMS
