Split Mode
Split Mode
I just uploaded my TX5K contacts to LOTW and ran in split mode during each contact. LOTW now shows that the band was in crossmode instead of 20m, 15m and so on. Went back to each contact and doubled click on it and went to the sataite tab and it shows 40m? it never switched to the band that I was on? So I guess I have to manually swith modes when in split? In the F1 qso tab shows the tx freq. corrrectly Tom.........
Re: Split Mode
Tom,
Please confirm what radio you are using and also if Omnirig or Hamlib for control?
Re: Split Mode
Tom had the check box for Satellite/Split checked (enabled) which caused the cross band condition. I've asked Lele to remove the split from the wording on the F5 screen. It's confusing as users believe you have to have it checked to work split.
