Hi, I've been using Log4OM for over a year now and absolutely love it..
However, just got a new computer with Windows 8.1 - Software runs great, but cannot figure out how to find the correct temporary path in LoTW settings.
It was easy to find in XP.. any ideas?
Thanks,
Brian
LoTW and Windows 8.1
Re: LoTW and Windows 8.1
temporary path is your choice.
This is the folder where Log4OM store the produced LOTW files just before send them to LOTW website.
You can periodically delete those files as you need.
In next release there will be a new folder in settings (or you can create a folder with that name), called TEMP, that will be cleared on every program restart.
C:\Users\YourName\AppData\Roaming\TrustedQSL
Replace YourName with the login name you use in W8.1
If you browse you cannot find those folders because they are hidden (even with setting show hidden files on)
