For contests I use N1MM with broadcast to upload QSO via UDP INBOUND to Log4om.
QSOs are not automatically uploaded to Clublog while if I log a QSO directly into Log4OM it works perfectly.
What could be the reason because I have already tried many parameters without finding the solution? I can’t find the answer on this forum.
Thank you, Leon ON4ZD
N1MM > Log4om2 > Clublog
Re: N1MM > Log4om2 > Clublog
1. You posted in the version 1 area of the forum which is not supported
2. You failed to read the release notes, user guide and numerous posts on this forum and social media.
As of 2.27.>>> you must update the UDP settings using the UDP edit facility provided
