"flexible" Windows in Log4OM ?
DO9KW
Post by DO9KW »
first of all I am very happy with Log4OM, ist is a brilliant peace of software.
2 small things that maybe could be updated somehow.
It would be very cool if the size of the band map could be adjustable in size because for the notes of the
stations you have to scroll to the right.
So it would be helpfull if the different windows could be flexible to adjust them for the own needs.
Also it would be fine to be able to change the "start screen" from the map view to the Recent QSO view because I personally never use the main screen.
Or lets say in other word to be able to edit the main screen.
73s
Stefan
DO9KW
Screenshot 2024-03-12 222909.png (23.28 KiB) Viewed 1899 times
Screenshot 2024-03-12 222751.png (130.7 KiB) Viewed 1899 times
73 Stefan
Re: "flexible" Windows in Log4OM ?
Why not use the floating bandmap - Connect/Band map
You can have one open for each band if you wish and they can be re-sized as you requested
DO9KW
Post by DO9KW »
Many thanks Terry, good hint.
Another solution could also be to be able to Zoom out one or 2 steps more so that also the notes behind the callsign would be visible
on the first sight.
73s
73 Stefan
