- RA1.JPG (218.34 KiB) Viewed 4179 times
"RA1" Prefix
"RA1" Prefix
On the cluster screen, my system always shows any "RA1xxx" call as an unknown country (country block empty, colored red). On the right side of the screen, it correctly shows as European Russia.
Re: "RA1" Prefix
Do you have the up-to-date country file? The date should be May 20, 2014.
RA1ANY resolves correctly here.
Chuck-K7PT
Chuck-K7PT
Re: "RA1" Prefix
Chuck:
Same problem here it does not come up with a country at all. I have May 20 th. country file.
Aldo VA3AG
Re: "RA1" Prefix
My country file is dated May 20.
Note that the callsign resolves properly when entered in the call entry area, looks up fine on QRZ, etc.
It is only on the cluster functions that it does not resolve properly. I have noticed this before on other RA1xxx calls, not just this instance of RA1ANY.
Try inserting a local test call into the cluster.
Re: "RA1" Prefix
I've updated the country file with a date of July 07, 2014 to correct this. Thanks for pointing it out.
