Hi, for some reason after setting windows as I want and after log4om restart windows appears in different order as I want? Did I missing something in the settings to save windows position?
Regards, Kes.
How to save windows position after restast
Rigs: FLEX-6300 Ant: 6 band hexbeam (by SP7IDX).
http://m0pkz.co.uk/
http://m0pkz.co.uk/
Re: How to save windows position after restast
Hi Kes, I don't think you missed anything. Log4OM always defaults to the "QSO Information" tab every time you start up, that is the way the program is.
Hope this helps.
Hope this helps.
Aldo VA3AG
No I mean the size of individual windows.By example map size and dx cluster size which I wan keep the same all the time. But after restart map size, cluster etc. not cumming back in the same size as I left last time?
Kes.
Kes.
http://m0pkz.co.uk/
http://m0pkz.co.uk/
Hi
I remember a post here (I will try to get it for you ) where Daniele told us taht this functionality is not available and , for the actual software architecture, could be available with a specific custom implementation to be done
73 de Don IK2EGL
Do you refer to the main cluster window, the one that manages the connection parameters?
This *should* keep size and position upon subsequent restarts...
Just updated to 1.20 but seems after program restart windows coming back to original position...map, dx cluster etc. Did I missing something in the settings?
So how I can lock windows sizes?
regards, Kes.
regards, Kes.
http://m0pkz.co.uk/
http://m0pkz.co.uk/
Kes,
Windows 7 is awful for 'remembering' windows positions.
I use a shareware utility ($10 to buy) that gives total control. Dev is very helpful and responsive. Give it a whirl - http://www.desksoft.com/WindowManager.htm. makes windows behave like a 50s housewife, hi hi.
Cheers
Guy G4DWV/4X1LT
Cheers
Guy G4DWV/4X1LT
Something could be screwed up in window position...
i'll check
i'll check
Thank you Daniele,
Yes it would be nice like other programs, the windows stays in the same position as before....
Like the map, dx cluster window position.... Not big deal but just thinking would be possible to implement this in the upcoming versions!
Once again! thank you for such a good software!
Kes.
Kes.
http://m0pkz.co.uk/
http://m0pkz.co.uk/
