Saving the tx frequency differently while working on the QO-100 satellite
ta4orz
Post by ta4orz »
While working on the QO-100 satellite, while our Rx frequency records in the 10ghz 3cm band, what settings should we make to automatically record my tx band as the 2.4ghz 13cm band? thanks.
Re: Saving the tx frequency differently while working on the QO-100 satellite
Are you in sat mode in Log4om?
ta4orz
Post by ta4orz »
TX and RX bands do not appear automatically. and also I want to convert the tx frequency to 2400000 mhz
Adsız 2.jpg (215.8 KiB) Viewed 1711 times
Did you look at offset?
ta4orz
Post by ta4orz »
The frequency changes with offset a, but offset b seems to be of no use. Can you help me with the settings?
resim 5.jpg (198.72 KiB) Viewed 1685 times
resim 4.jpg (195 KiB) Viewed 1685 times
resim 3.jpg (24.4 KiB) Viewed 1685 times
