Started to use cw keyer interface connected to a serial port via a transistor keyer interface.
After specification of com port number , key pin and ptt pin everithing works as expected.
The problem is when I restart keyer interface : the comport number remain as wanted but key pin and ptt pin reurns to default values (DTR and RTS) and not the wanted "key pin = RTS" and " PTT = none" as required by my interface.
73 de I0MOM Marco
CW Serial settings key pin and PTT pin not saved
73 de I0MOM Marco
Re: CW Serial settings key pin and PTT pin not saved
Known issue and should be fixed in next release
