LotW
df6vi
LotW
Post by df6vi »
Hi all,
has anybody experiences in uploading QSO's from a Log4OM adif file into LotW.
The QSO's i selected, transfered (*.tq8 formated file) and uploaded, are not shown in LotW under "most recent QSO's".
Only very old entries from the last year are visible.
Any Ideas?
73, Stefan DF6VI
JA9HWD
Re: LotW
Post by JA9HWD »
df6vi wrote: 15 Apr 2024, 17:04 Hi all,
Any Ideas?
73, Stefan DF6VI
I have very little experience of failures when uploading ADIF files to LoTW unless there is a problem or congestion in LoTW.
I think it means that the upload is not a "request".
73, Kiyo JA9HWD
df6vi
Re: LotW
Post by df6vi »
Found the mistake.
For whatever reasons the Locator wasn't set correctly (nothing has been changed in the settings). So the synchronisation failed.
73, Stefan
JA9HWD
Re: LotW
Post by JA9HWD »
df6vi wrote: 16 Apr 2024, 17:02 Found the mistake.
73, Stefan
It means that it was rejected because the QTH of the profile registered in LoTW does not match.
Thank you for the report. I'm glad you were able to resolve it.
73, Kiyo JA9HWD
df6vi
Re: LotW
Post by df6vi »
Hello Kiyo,
exactly. I edited a few QSO‘s wie the correct locator, generated a new tq8 via the Tqsl software (with no error message) and uploaded it on the LotW Homepage. Everything worked fine now.
73, Stefan
N4RF
LoTW Uploading
Post by N4RF »
I can no longer upload to LoTW from Log4OM. I select the QSOs and then upload. I get the error: Creating folder access to the path 'C:\users\N4RF\AppData\Roaming\Log4OM/\temp' is denied.
I am uploading directly to TQSL.
Bob N4RF
Pinehurst, NC USA
Re: LotW
LOTW has been down for a few days because it was hacked
JA9HWD
Re: LoTW Uploading
Post by JA9HWD »
N4RF wrote: 23 May 2024, 14:17 I can no longer upload to LoTW from Log4OM. I select the QSOs and then upload. I get the error: Creating folder access to the path 'C:\users\N4RF\AppData\Roaming\Log4OM/\temp' is denied.
Bob N4RF
Pinehurst, NC USA
I hope it recovers quickly.
171 QSOs remain in "Request" state since LoTW went down.
My concern is that Log4OM2 may not be able to correctly recognize the server status during downtime and when it is busy after recovery, and will rewrite the status to "Yes" even though the upload has failed.
73, Kiyo JA9HWD
N4RF
Re: LotW
Post by N4RF »
I still can't upload or download to LoTW. I am not uploading directly to LoTW and get a match occasionally which shows up on the Account Status matrix.
Also, my Log4OM logbook shows zero LoTW Sent and Received. I have 2300 challenge points, so I have been at this for a long time. HOw do I make my log book match LoTW Sent and Received?
Bob N4RF
JA9HWD
Re: LotW
Post by JA9HWD »
N4RF wrote: 21 Dec 2024, 21:34 I still can't upload or download to LoTW. I am not uploading directly to LoTW and get a match occasionally which shows up on the Account Status matrix.
Bob N4RF
Hi Bob,
You probably have other problems that didn't show up in this thread.
For example, incorrect QTH information or valid dates when sending to LoTW. Such problems don't matter if you're sending via TQSL, UDP controlled sending, or uploading via ADIF.
However, I think that Log4OM will write any problems to the execution log, so I recommend looking for error messages in the execution log.
73, Kiyo JA9HWD
