Lost Database - SQLITE V2.32.1.0
on6at
Post by on6at »
As in version 2.32.0.0. and previous versions, I notice that you regularly lose the connection to your SQLITE database.
However, everything is correct in the configuration.
See Configuration > User Configuration > Station Information > Database. There it says Database = SQLITE and the path is
C:\Users\name\Documents\LOG4OM2\ON6AT.sqlite
After I have been active for about 2 hours, I see that the log is no longer updated.
The filtering also no longer works. THIS way I know that the DATABASE sqlite has stopped working.
I always have to consult the backup and restore everything.
This is very annoying.
How could it be that you keep losing that database link?
73's de ON6AT Patrick
73 Patrick ON6AT
Member UBA-IPA
WCA: ON-01354
