LotW upload problem
Pa0ply
LotW upload problem
Post by Pa0ply »
I am configuring a new laptop for our clubstation.
It uses WSJT-x / Log4OM / LotW connections.
Logging a QSO from WSJT-x to Log4OM works ok.
Uploading QSO's from Log4OM to LotW fails for any reason.
In the manual upload mode I see following:
"ADIF files correctly generated
Cannot find the ADIF in the given path."
I tried to find the adif file on the computer but got No Result.
The TQSL certificate is installed correctly in the Log4OM sw as well as on the LotW website
But on LotW: No QSO found.
Please advise
Jan, PA0PLY
Pa0ply
Re: LotW upload problem
Post by Pa0ply »
I tackled the problem.
I made a temp file in the settings, but you will need to leave this line open as TQSL will generate its own temp file. That is why it could not find the generated adif file.
Now the adif file is uploaded to LotW, although I did not see its appreance yet
Br. Jan
Pa0ply wrote: 24 Apr 2024, 13:58 I tackled the problem.
Br. Jan
Br. Jan,
The 'temporary file' is noted (and required) in the "current" User Guide on Page 127.
Pa0ply
Post by Pa0ply »
Correct, but the manual says one has to set this temp file.
However you should let TQSL generate this temp file as then the adif files are routed correctly.
Br. Jan
All works fine now and my test qso’s appeared at LotW as well.
