CWSkimmer and Log4OM
F6FLU
Post by F6FLU »
Good morning
what connection must be made so that if we click on a call from CWSkimmer it is received by Log4OM ?
THANKS
Dan - F6FLU
https://F6FLU.org
F6FLU
Re: CWSkimmer and Log4OM
Post by F6FLU »
amazing :-)
Nobody uses CWSkimmer with Log4OM?
I can not believe it ;) ;)
Dan - F6FLU
https://F6FLU.org
LB2EG
Post by LB2EG »
Hi Dan,
Clicking on a callsign in Cwskimmer does (afaik) not populate the QSO field in Log4OM or any other logging program.
The only way in CWskimmer to export callsigns to is through its telnet server.
Connecting cwskimmer telnet server to Log4om cluster client, will populate the LOG4OM cluster view and bandmap with calls decoded by the cwskimmer.
73 de LB2EG Richard
F6FLU
Post by F6FLU »
thank you Richard, I'll do it like that I had hoped there was another solution 😏
thanks again
Dan - F6FLU
https://F6FLU.org
