Hi
When I upload to LOTW I get an error won't upload due to no valid certificate for cal IU5PSY my call G1DLC i have to say ignore errors to upload
if I go into edit qso call sign in LOG4OM IU5PSY is in station callsign instead of G1DLC in the past all was ok I cannot get rid of this call sign IU5PSY
is this a log4om problem or TQSL ?
Don't get old
John
Error upload TQSL
Re: Error upload TQSL
Where in log4om are you trying to edit call?g1dlc wrote: 06 Jul 2024, 12:41 Hi
Don't get old
John
hi terry
thanks for the reply i did not want to edit qso but it was the way i found out that my station callsign was IU5PSY ,i went into recent qso highlight a qso ,it goes to edit qso ,in my qth thats were my call station callsign is IU5PSY i have edited some call signs and corrected my station call sign to G1DLC
my station callsign has been correct in the past but i don't know were this has come from i have worked this station ,i have taken callsign out temporarily to see if this would fix problem but it doesn't
its only when i switch of lo4om to send lotw qso it come with error that the call IU5PSY has not a valid certificate and i have to say ignore error,it used to work fine in the past
my station information is still all correct with station callsign G1DLC
Terry hope you can follow this
dont get old
john
dont get old
john
g1dlc wrote: 06 Jul 2024, 19:45 hi terry
dont get old
john
Hi John,
Where are the QSO's coming from, wsjt???????????????????
1. In settings/Program configuration
Open the 'Station information' tab and make sure the station, owner & operators calls are all set to G1DLC
Open the 'External services/LOTW' tab and ensure that your user name is set to your callsign and that the Password is the one that you use to access the LOTW website
Click save & Apply
2. In Utilities/QSO manager
Select all QSO's with the incorrect station call sign and bulk edit using the 'Single field update' tab to correct the station call sign
Once the above is complete any QSO's logged in Log4OM manually via the input window or keyer window will have the correct station call sign logged.
However if some external aplication is logging to Log4OM either by UDP or Adif monitor sends the wrong station call the problem will reocur
Hi Terry
i have successfully updated station callsign in qso manager
most qso are from wstx via grid tracker
the station IU5PSY is still there can i get rid of this or will i have to manual change station callsign on all qso from now on
wsjtx and grid tracker have all my details correct callsign ect
can i find out which programme is at fault
Terry 73s
thanks again love this programme
John
Terry 73s
John
Where?the station IU5PSY is still there
Something is wrong in gridtracker or WSJT if you have completed the changes I detailed and it still happens, have you checked what details are in the other programs options settings?
Hi Terry
I have finally sorted call sign problem
In external services, QRZ had IU5PSY in force station callsign, changed to G1DLC now running perfectly
Thanks again for you time and stay young (83yrs)
G1DLC John
G1DLC John
- Capture.PNG (18.35 KiB) Viewed 978 times
