Dear readers,
I recently installed wsjtx 2.7.0 rc5 (so called super fox).
After installation the wstx rc5 runs smootly but i lost my CAT connection in Log4OM v 2.32.1, it is set to "OFF LINE".
No QRG readout in display.
Strange thing is that when i run wstx 6.2.1 regular version i dont have this problem. Even the old L0g4OM V1
has a good CAT connection with the new wstx 2.7.0 rc5 running. I use Omni rig.
What could be the trouble?
73's
Gerrit
PA3DJY
CAT accessing with WSJT
Re: CAT accessing with WSJT
Logic says...........
1. It worked before a wsjt update
2. it works with previouse WSJT version
3. Using old WSJT version it works with both versions of Log4OM
Logic answer = There is something changed in WSJT latest version or its no longer set up correctly
