ffma allowed dxcc country numbers
I was browsing around log4om, and came across this issue, and wondering if I can correct it, or is it a file supplied from log4om. it appears several grids are labelled as 1291 or 50291, instead of 291
- ffma grid.png (6.57 KiB) Viewed 1803 times
Dave ve3wej / ve3ie
Re: ffma allowed dxcc country numbers
I dont think its the award that is the issue I think its the QSO!
Check in QSO Manager by filtering Country (EQUAL) empty
I think you will probably find the QSO was with a /MM assigned to a grid but not actually in the country - No DXCC
Anyway once the QSO is identified by filtering you can then edit the information
I did check one entry ( mexico) with qrz having a us address, so it thought it was texas
but cn78 in my capture has NO contact made, so no it will not be a /mm, and I stopped working /mm when I found no dxcc value...
Dave ve3wej / ve3ie
Did you do as I suggested??????????????ve3wej wrote: 29 Jul 2024, 16:29 I did check one entry ( mexico) with qrz having a us address, so it thought it was texas
now i see it, the 1,291 is not an error, it is telling me that grid could be in country code 1 or 291
so 50,291 is country code 50 or 291
Dave ve3wej / ve3ie
