Hi Lele, Terry,
Is there a way to have this window always on top like the Winkeyer window ?
I cannot find this option anywhere.
Compact Data Entry // Always on top
73 de F4BPO Greg
Re: Compact Data Entry // Always on top
Not at the moment but it could be done
Moving topic to Freature Requests
That would be awesome cause each time we interact with a SDR program to change frequency the windows falls on the back and need to bring it back all the time.
That is a bit boring.
Thanks a lot
Thanks a lot
73 de F4BPO Greg
Depends onm your SDR setup!F4BPO wrote: 30 Jul 2024, 12:48 That would be awesome cause each time we interact with a SDR program to change frequency the windows falls on the back and need to bring it back all the time.
Thanks a lot
I have Sunsdr which was the same so I purchased an ecoder, now I dont have to have focus on the SDR software window so can change radio and log or use macros at the same time - No Messing!
Doing the same with my Hermes Lite 2+
I use SmartSDR with Flex 6600.
But it is an issue even if using other software unless you use the data entry on a different monitor.
Anyway this option would be very helpful.
73 de F4BPO Greg
