After printing Bureau QSL labels - QSL confirmation shows via Electronic not BUREAU
G5ART
Post by G5ART »
Am I missing something?
After I print all my QSL labels and save the results to my log database.
If I then goto the edit QSO window and look at the manage confirmation window, selct QSL from the drop down list. I see SENT is set to YES with the correct date but the VIA tab show Electronic and not Bureau or Direct as per my selection in the label printing window.
Is this correct? as its rather confusing if I receive a qsl card and check the qso confirmation I cant see if Ive sent direct or bureau or definitley sent a card on that date as the via method is electronic!! But I will also have sent an EQSL which is Electronic.
I
Fat Finger Typing can often cause things to break!! :? :shock:
Re: After printing Bureau QSL labels - QSL confirmation shows via Electronic not BUREAU
I assume your looking at the QSO info screen in the edit window? that is the default view before editing it does not reflect the method a QSL was sent by.
See recent QSO's (F7) QSL Via column which will display the 'Variouse' metods you sent confirmation by.
That field could show LOTW, Direct, eqsl indicating that you had 'Confirmed' by three ethods i.e. LOTW - Direct - Eqsl
Or it might just show 'Direct' if you only confirmed by a paper QSL
