Hi all,
I downloaded and installed the Current release 2.33.0.0 (25/07/2024).
Yes, my subscription at QRZ is valid AND my API key is filled in.
After establishing that the upload to QRZ did not work, I reverted to the previous release (Version 2.31.0) and that resolved the upload problem.
Please fix... ?
73, PD1GAW
Current release 2.33.0.0 (25/07/2024) not uploading to QRZ
Re: Current release 2.33.0.0 (25/07/2024) not uploading to QRZ
And now, I'm sorry to say, the previous version does not upload anymore to QRZ either...
Is something wrong with the XML process?
PD1GAW
PD1GAW
I just uploaded 22 QSO's to QRZ whithout issues
Are you sure the station call matches in theQSO's, Program Config/Station Info and External services.
QRZ end date OK?
Clearly something set wrong in your system because noboby else has reported this and I just tested it OK
QRZ end date OK?
I will (re-)check the configuration tomorrow. Switched of my PC now.
The subscription end date is somewhere in May 2026, so that’s okay.
Thanks,
PD1GAW
Thanks,
PD1GAW
Not subscription end date the LOGBOOK end date shown in Logbook/settings/Logbook info of QRZPD1GAW wrote: 15 Aug 2024, 14:11 Hi,
Thanks,
PD1GAW
The end date of my logbook is 2024-12-31 at the moment, so that should be okay, right?
YesPD1GAW wrote: 15 Aug 2024, 19:42 The end date of my logbook is 2024-12-31 at the moment, so that should be okay, right?
Station call matches everywhere.G4POP wrote: 15 Aug 2024, 13:51 I just uploaded 22 QSO's to QRZ whithout issues
QRZ end date OK?
WSJTX publishes QSO's in the network (GridTracker is receiving them, LOG4OM is receiving them as well).
Settings checked and double checked, altough they have not been changed (by me).
Any more ideas?
Have you tried a manual upload to QRZ from QSL Manager in Log4OM
Have you checked the UDP connection to ensure 'Upload QSO' is checked as in our user guide page 234
Uploading through the QSL manager works!
I now will try whether automatic upload works too.
‘Upload QSO’ is checked in the UDP inbound from WSJTX.
PD1GAW
PD1GAW
