Reconnection of Cluster not working anymore
DO9KW
Post by DO9KW »
I am using latest build 2.33.0.0 but I have a problem with cluster reconnection since using this build.
Normally the cluster disconnected in older builds when Log4OM was idle for a longer time (for example over the night).
Then I could reconnect manually (connect - telnet cluster) but now this does not work anymore.
After some time I cannot connect anymore, no matter what server I chose.
It only helps to close and re-open Log4OM again.
Maybe you could have a look at it.
thanks and 73s
Stefan
DO9KW
73 Stefan
Re: Reconnection of Cluster not working anymore
Thanks, some activities were done on that, but probably i still need to find the right path...
Lele will look at this when he returns after his vacation
