Thank you in advance you all are the best love Log4OM
If you refer to the world globe in the input interface (Betweeen the plus sign andred cross) it never has updated the data it opens a lookup in the web browser?KS4VOL wrote: 23 Aug 2024, 10:21The Refresh Data (World Globe) to update QSO now will not update with contacts Name and QTH and possible anything else again. Am I the only one having this problem or am I the only one that uses it?Was it deactivate?
OK now we have established exactly which icon you refer to, you are correct that it will update missing QSO data which it obtains form whichever on line info provider you selected in the Program config.KS4VOL wrote: 28 Aug 2024, 10:12 Thanks for responding Terry
Now I am confused. See my other post on the subject
KS4VOL
Contact: Contact KS4VOL
Refresh Data (World Globe) Edit QSO changes ITU & CQ zones incorrectly.
Post by KS4VOL » 04 Mar 2024, 09:50
If you go to the Recent QSO's in the main window. and double click on a QSO the Edit QSO window pops up. the world globe in the gray field use to update missing information that would have missing fields from WSJT when logged. At least that is what I remember it did months ago as I would be missing Operator name and QTH. You remember I said it was changing the ITU and CQ wrong? It use to add Operator name and Contact's details. That is how I use to update the missing info. So you never pulled info from QRZ or where ever. Maybe I am going mad and I am getting older and forgetful more at each passing day Terry.![]()
Hope this clears it up sir and as alway thank you for what you guys do.
