I was looking for a way to generate a list with stations I worked for the first time per band.
Is that possible within Log4OM?
Br,
Jan PAoPLY
List of QSO’s made first time
Re: List of QSO’s made first time
No preset way but the best I can suggest is to use QSO manager and first filter by the band and mode of interest
Then in the QSO window click the date title field name to sort by date in accending order - first QSO on that band/mode will then be at the top.
You could probably do it using a regex but that would be a bit complicated and open to errors
Thanks for the suggestion.
I am afraid that will not match our goals.
At the moment we, at EME, list the QSO’s as initials per band.
Myself, I publish this list on my website for each band.
I keep track of my first contacts in a MSdatabase, while since a few years I also use your Log4OM for logging all qso’s, as it automatically use the completed QSO’s from WSJT-x.
In the MSdatabase I have a query to select those stations worked for the first time.
Br. Jan
Br. Jan
