My lookups for call signs are QRZ.COM as primary source and HamQTH as failsafe.
For some reason I never see the image or photo that hams use on QRZ.COM (primary image that shows in upper right corner). In other software it showed up...
In configuration I checked the show profile image in main user interface.
73 Phil ON4VP
Photo or image in Stats (F1) window
Re: Photo or image in Stats (F1) window
As I already pointed out your a QRZ ham member which does not include that priviledge you must be a paid XML subscriber see our FAQ at viewtopic.php?t=4461ON4VP wrote: 30 Sep 2024, 14:30 My lookups for call signs are QRZ.COM as primary source and HamQTH as failsafe.
73 Phil ON4VP
Ah ok, did'nt know it was for viewing also. So I need the XML suscribing...
Thanks, Phil
Thanks, Phil
I am having the same issue, and Terry, I went through you checklist, and all is correct, and valid dates
login returns a check mark in green, xml is valid til 05 2025
user does display a image online
try my call and see if my mugshot shows up in your log4om 2.33.0.0
not sure where else to try
Dave ve3wej / ve3ie
Yes your call displays image OK
Screenshot of info providers menu tab please
