POTA - WB4 - Highlight Issue ... Maybe??
I've noticed that all the POTA Notes are 'highlighted' in the Cluster (F8) tab.
That is not a bad thing, as such, but many of those POTA sites have been WB4 and confirmed in my log.
The WB4 OM's callsign is properly highlighted, but the Cluster (F8) Notes are also bright yellow/gold.
Seems to me that once the POTA is worked that the highlight should not be used.
A hiccup in Log4OM maybe?
Re: POTA - WB4 - Highlight Issue ... Maybe??
Hi Nolan,
The highlight of the notes is only to indicate that there is an award reference stated, its nothing to do with not worked ("Needed").
You and I previously discussed that the 'Award highlight' choice in the Program config/cluster menu is not working i.e. the user can select an alternative colour but the colour is not implemented.
Were you able to change the 'Award highlight' colour you would not confuse the notes highlighting as an indication of not worked before.
You could of course change the 'Band/mode not wrkd/conf' colour to say purple, to identify the difference between not worked and the award alert highlight colour.
Screenshot 2024-10-07 141023.png (13.52 KiB) Viewed 1733 times
