I am trying to use the udp outbound mode to send my adif loggings
to my local robot. I enter the info :- Port 23308.
Connect name:- TARS ROBOT.- Service type:- ADIF Message
IP Address:- 81,174,154,157 - click green arrow, - click green tick.
SAVE/APPLY. when nil happens . I go back to "connection" and
all the info has disapeared & not been saved, any help\??
I'm running WIN 10, LOG4OM vir 2.33.0.0
73 de Derrick G3LHJ.
Software Intergration / connections
Re: Software Intergration / connections
Try using full stops (Dots) instead of commas for IP address
I just tested here and the setting is saved and persistant on restart
Hi, Have made sure that it's "dots" between the IP Address, and it is still not saving .
73 Derrick G3LHJ
73 Derrick G3LHJ
Did you install to the default directories, there is no reason it would not save unless you installed to somewhere that has restricted access priveledges.
Try a new install
Try a new install
