wrong modulation when inserting spot cluster
IZ1252SWL
Post by IZ1252SWL »
Hi everyone! It's happening to me in the 2 meter band that when I insert a spot in the cluster by filling in the appropriate fields at the top left and taking care to select the FM item from the MODE field drop-down menu, when the spot is displayed in the cluster, the MODULATION field says USB....where am I going wrong? 73!
AB7R
Re: wrong modulation when inserting spot cluster
Post by AB7R »
I have a similar problem. Running a skimmer server for CW only. All spots show modulation as USB and some show emission type as digital. The spots are indeed CW. Is there some txt file that auto sets mode based on frequency? Even shows W1AW as digital at 7047.5.
pic attached
Greg
AB7R
cluster modes.jpg (228.67 KiB) Viewed 409 times
Greg - AB7R
Caldwell, ID
AB7R
Post by AB7R »
OK.... I found the band plan xml files and modified the one for IARU R2. But I am still having the same issue. I there any of the other files that need to be changed?
Greg - AB7R
Caldwell, ID
