OMNIRIG not connecting
m7gdu
Post by m7gdu »
Hi
I've been using LOG4OM for over a year now with no issues.
Today, though, it's developed a problem.
It's no longer pulling the frequency/mode/etc from my FTDX10, despite working flawlessly for all this time. I'm just getting "offline" displayed. :(
Things I've checked...
  • Full reboot of rig and computer
  • Downloaded latest version of LOG4OM
  • Confirmed radio is talking to computer by checking WSJTX - all works fine there
  • I can confirm OMNIRIG opens in the background when I open LOG4OM
  • I'm seeing this in LOG4OM log file - "2024-10-30 08:23:07.7709 INFO: [OmnirigEngine] : CAT OMNIRIG2 -> LOG4OM RIG1 IS ONLINE"
  • Apparently you can get OMNIRIG to output to log file by adding "[Debug] Log=1" to omnirig.ini (instructions don't go into any more detail, so not even sure where omnirig.ini should be saved). I'm not seeing a log file generated anywhere.
I'm at a loss. I work in IT, so feel free to speak in IT terms.
BTW - I tried doing a search on the forum for OMNIRIG, but got the following...
The following words in your search query were ignored because they are too common words: omnirig.
You must specify at least one word to search for. Each word must consist of at least 3 characters and must not contain more than 14 characters excluding wildcards.
ve3wej
Re: OMNIRIG not connecting
Post by ve3wej »
I sometimes see that happen as well. try changing to rig 2 on log4om, then change back to rig 1
rig 1.png (5.45 KiB) Viewed 401 times
Dave ve3wej / ve3ie
