First, I wish I could release the Com port without closing Log4OM. I often switch between WJST-X and Log4OM controlling my radio. While I can disconnect Log4OM, it hangs onto the Com port so WSJT-X cannot connect.
Second, I wish I could set a default for View-Statistics so that it starts up in LoTW confirmations and Don't Hide Not Worked.
BTW, I very much like View-Statistics and use it often as I pursue raising my LoTW Challenge total. It's a neat feature that I didn't realize for a while was there.
Thanks for all your great work on Log4OM.
Two suggestions, unless I'm missing how to do this in version 2.33.0.0
Best wishes,
Ted Szypulski
K2GAV
Kenwood TS-990, Elecraft KPA-1500
Ted Szypulski
K2GAV
Re: Two suggestions, unless I'm missing how to do this in version 2.33.0.0
If you used omnirig in the way reccomended with wsjt then both programs could simultaneously communicate with your radio thereby removing the need to change software control
