Two suggestions, unless I'm missing how to do this in version 2.33.0.0
Posted: 31 Oct 2024, 14:54
by K2GAV
First, I wish I could release the Com port without closing Log4OM. I often switch between WJST-X and Log4OM controlling my radio. While I can disconnect Log4OM, it hangs onto the Com port so WSJT-X cannot connect.
Second, I wish I could set a default for View-Statistics so that it starts up in LoTW confirmations and Don't Hide Not Worked.
BTW, I very much like View-Statistics and use it often as I pursue raising my LoTW Challenge total. It's a neat feature that I didn't realize for a while was there.
Thanks for all your great work on Log4OM.
Re: Two suggestions, unless I'm missing how to do this in version 2.33.0.0
Posted: 31 Oct 2024, 20:54
If you used omnirig in the way reccomended with wsjt then both programs could simultaneously communicate with your radio thereby removing the need to change software control
