How to globally set LOTW flag as sent?
W2UP
Post by W2UP »
I imported my log (via ADIF) from another logging program and upon import, the LOTW sent flag is set as No in log4om. My LOTW submissions are up to date, so I can I globally set the old QSOs to Yes in the LOTW sent field?
Tnx,
Barry W2UP
Re: How to globally set LOTW flag as sent?
W2UP wrote: 04 Nov 2024, 01:56 I imported my log (via ADIF) from another logging program and upon import, the LOTW sent flag is set as No in log4om. My LOTW submissions are up to date, so I can I globally set the old QSOs to Yes in the LOTW sent field?
Tnx,
Barry W2UP
Barry,
Noted in the User Guide.
Use the QSL Manager and select the LOTW dropdown, filter the calls you need to modify and then use the modify option in the QSL Manager field.
I've done it a number of times over the years as I've imported historical ADIFs. Very easy.
W2UP
Post by W2UP »
Tnx, Nolan. Turns out I was doing it correctly. What I missed was the fact it brought up the next group of 20K QSOs at the end of the flag change and all I saw was NO in the LOTW Sent field. I went back and noticed the different callsigns and dates.
Barry W2UP
