Hi all,
Today i runned my first contest in the "contest mode" of log4om and it worked well.
But .. i needed to deliver my contest log, and here it started to become complex.
They want to have a Cabrillo format log. Well, i exported the contest fields to a ADIFF and expected to be able to convert it with the help of this site
https://www.cqwpx.com/adif/
It almost worked but i received an error "QSO time not within contest period in ADIF QSO 1 [PB38EUDXF]. QSO removed".
I wanted to fix this, and tried to maken an export to csv, and from there reconstuct the needed data but, when you export all fields it seems one field is missing the: "Exchange Received Tag". Could someone confirm this datafield is, or should be in the export function of log4om. If so what is the name of the field in the CSV export?
Regards
Eelco
Fields missing, and or database issue?
Re: Fields missing, and or database issue?
Log4OM exports the authorised ADIF data in SRX, SRX_String, STX & STX_String
See adif data format here https://adif.org/314/ADIF_314.htm in the 'Fields' section
Suggest you either set the wrong start time for the contest or the conversion program has an issue
Thanks, i managed to convert the log by using your additional information.
With some help of you and others (CQ WPX Contest Committee) it is possible to build op a cabrillo log with this site:
https://adif2cabrillo.com/index.php
Regards Eelco de PD1EG
