How to setup specific filter?
PA3EXV
Post by PA3EXV »
We use Log4OM mainly for EME activities on VHF, UHF and SHF bands. Here it is nice to know the count of initial calls done so-far and present them on a private webpage as .htm-file. We are struggling how to create a filter which supports this. The filter should take only the unique QSO's based on the call, on a selectable band, between selectable dates. Preferably then be able to generate webpage from the result.
May be like SELECT DISTINCT Callsign FROM LOG Where ..... or similar?
I am no expert.....
Please help us in guiding the correct direction, thank you.
Re: How to setup specific filter?
I assume that by distinct you mean Unique call signes?
If so there is no provission for that at this time
