Hi all,
We had to enter completed qso’s manually in log4omv2 but came across following:
Entering the details including an end date/time it appears in the database, but it does appear with the current date/time. So the original date/time of the QSO is not converted to the log.
To solve this we had a work around by editing the QSO again and change the date/time details again.
This time it takes the correct date/time.
Are we doing things wrong?
Br. Jan, PAoPLY for PI9RD
Problem with manual entry of QSO’s
Re: Problem with manual entry of QSO’s
I have just spent 20 minutes entering QSO's using both the automatic time recording and also by manually setting the start and end time as I would for old QSO's.
Whichever way I do it it is recorded correctly for me so I think I need a more exact and step by step explanation of what your doing illustrated with screen shots. Unfortunately that is the only way we can help you as I cant emulate your issue here
BTW I ALWAYS NEED THE ACTUAL VERSION NUMBER, "LATEST RELEASE" WONT DO! - Why you ask? Because if your using an older version I need to install that version to test and in any case it may have been a problem in an earlier version which was subsequently fixed.
