Resource editor
ON4VP
Resource editor
Post by ON4VP »
I did not find this in the manual (I think).
I tried to add some contests in the contest.csv file.
When I saved the file, it appeared in the user edited resources.
Schermafbeelding 2024-12-22 092657.jpg (66.18 KiB) Viewed 1631 times
After restarting the program the new contest was still not listed in the pull down menu (contest settings menu).
What am I doing wrong?
Thanks Phil ON4VP
Re: Resource editor
You spotted an issue the file is not being saved and not recognised on restart
Will be fixed
ON4VP
Re: Resource editor
Post by ON4VP »
Thanks !
Re: Resource editor
I made a test, adding a new contest called "TEST" separated by a ";" from his code (TEST)
and the contest is there, ordered by name (maybe that's the problem? you expected it at the end of the list?)
Did you find the contest, when selecting the contest_user file, in the list?
Re: Resource editor
Silly mistake but I did EXACTLY the same when I tested - Missing semi-colon (;)
