MySQL : latest version
Posted: 01 Jan 2025, 10:07
HI !
I migrated all my programs to a new computer with windows 11.
I reinstalled Log4OM and copied the various configuration files.
No problem, all good. 100% working.
On the previous computer with windows 10 I had chosen to use a MySQL instance.
At the moment on the new computer I have been using Sqlite.
Now I wanted to switch to a database server.
I have a question.
In terms of (1) performance and (2) compatibility, is the MySQL Community Server 9.1.0 Innovation version the best or is it better to use MySQL Community Server 8.4.3 LTS or MySQL Community Server 8.0.40 ?
The 8.0.40 version has a convenient installer with everything in one package but there are no problems at all installing the workbench component or anything else needed.
I tend to always install the latest versions that should be better in terms of performance and problem solving, so I would go with 9.1 if Log4OM is 100% compatible.
For any questions about the reason for migrating to MySQL, the answer is that I am interested in a system that is as reactive and as fast as possible (I have a medium-sized log) and above all I want to be able to access the database concurrently from my other applications while using Log4OM.
In this regard, I have one last question: is there a tool to migrate data directly from Sqlite to MySql or is the procedure always to go from export adif and then import adif?
Thank you very much.
Best 73 de Rick I2BRT
I have a question.
