nombre de bandes dans le cluster?
French language forum v2
F1POK
Post by F1POK »
bonjour à tous
malgré mes recherches le cluster ne me fournit que les cinq bandes classiques.
j'aimerais pouvoir recevoir les infos des bandes WARC également ... une idée ?
merci 73's
Re: nombre de bandes dans le cluster?
Jean-Luc,
It is described in the 'current' User Guide.
Regardless ... I'm sure you have not make appropriate band selections at: Settings / Configuration / User Preferences
You can select the bands you prefer to have appear in the "Preferred Bands" column.
Be sure to properly save your choices. Then restart Log4OM and the bands you have selected will then be available for you.
F1POK
Post by F1POK »
thank you very much Nolan!
it's been a while I was looking in all the menus.
thanks again and looking forward to contacting you on the air
best 73's
The user guide is always a good place to start
