Version 2.35.0.0 released today
The download is here https://www.log4om.com/download/
Release Notes
[NEW] Added SUBMITTED and GRANTED search capability on all QSO grids for specific award code
[NEW] Added support for SDC Skimmer spots
[NEW] Added capability to download LOTW QSL data when user has multiple logbook DXCC Award accounts.
[NEW] LOTW digital confirmations and paper QSL can be independently downloaded (digital, paper or both) and not only ALWAYS DIGITAL + optional QSL confirmations.
[NEW] Added support for external club membership lists (settings – user preferences). Check user manual!
[NEW] Added new “security settings” menu in program configuration. This will allow Log4OM to work with external sources that doesn’t comply with latest TLS 1.2 security encryption protocol (by selecting other specific security protocols allowed) and eventually working with services that exposes expired or wrong web certificates. This may solve some integration troubles and errors reported in the log at the cost of a slightly increased risk during access to those external sources. Basically some club membership lists are hosted on a webserver with an expired cert and won’t be updated with default settings. Always check the application log if something seems not updated correctly!
[NEW] Added support to SFTP on webpage upload
[NEW] Added option in cluster alert to skip alert for WORKED callsigns (works for same call worked in the same band/emission type/mode of the current spot)
[NEW] Added new “Perform DB maintenance” menu under “Settings -> Maintenance” that will make a reorganization of the main database (SQLITE ONLY), award database and external data database, reducing size when possible and reorganizing data for better performances on HIGHLY fragmented databases (do not use too often).
Updated code for IOTA automatic data download, as changed by IOTA program.
Revised code that handle image view in external window
[FIX] Fixed an issue on alerts when multiple confirmation methods were selected in “not worked” alert
[FIX] Fixed an issue that prevented export of RECEIVED data for some awards when working with “standard ADIF” without Log4OM specific fields
New Release V 2.35.0.0
